Ir para o conteúdo principal
The Garmin Nuvi 200 is part of Garmin's 200 series of GPS navigators. It was released in May of 2007. It comes with preloaded maps of the entire continental U.S., Hawaii, and Puerto Rico. It is available in classic silver or pink.
13 Perguntas Visualizar todos
nuvi 200 stopped locating satellites.
Worked fine, then: searching for satellites forever. Everything else is working. Updated software, chipset, downloaded new maps, reset it dozen times, put it outside away from buildings for a day and it is still somewhere in Kansas.
Any help?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I noticed you never got an answer to this. Are you still having this problem
por
Adicionar um comentário
2 respostas
Solução escolhida
Why not try this. Perform an update using Garmin's WebUpdater. Update to the newest version and also update the "Chipset M" which can be selected as an additional update after the firmware has finished updating. Then perform a master reset using the button on the back of the unit with the unit turned on. Garmin Updater and Garmin's solution Since you are not in Kansas anymore, you have really nothing to lose....good luck
Esta resposta foi útil?
Pontuação 2
Borré de manera erronea los mapas que venian originalmente con mi Nuvi 200w y ahora no sé como restaurarlos, me ayudan?
Pontuação 0
Adicionar a sua resposta
eurocloset será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 12,029
