Ir para o conteúdo principal
Lançado em 1990 como sucessor do Apple Extended Keyboard. Os modelos M0312 e M3501 foram produzidos, utilizando os lendários switches táteis ALPS ou os switches lineares mecânicos padrão da Mitsumi.
command shortcuts not working
I wiped down my keyboard with one of those lysol wet wipes and now my command key won't work ... for example: I'm in InDesign and my command C just types a c and doesn't copy. I have the extended keyboard plugged into my MacBook Pro. I wiped down both keyboards. Now I can't figure out how to restore my command shortcuts or if I got the inside of my keyboard wet. But all the keys work as a typewriter, just not the commands. I'm thinking that I somehow locked the command out or something as I rubbed over all the keys, but have no idea. Anybody?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Being able to reroute some keys may help with your trouble shooting or give you a temporary solution. For instance I have rerouted my CAPS lock key to ESC because it is more useful.
This app does the trick:
https://pqrs.org/osx/karabiner/seil.html...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jpgrahamjazz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 497
