Ir para o conteúdo principal
A câmera Polaroid OneStep 600 tira e revela as próprias fotos. Ela possui um flash automático, além de uma lente especial para fotos em close.
Displaced spring in film release button?
A spring fell out from the left side of the film cartidge loading bay and I can figure out where it goes. It is a large u-shaped with a hook at each end. I am surmising it works to activate the release button to load film. If I had a schematic or exploded view of the camera, it might help to relocate it. Any suggestions?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
i think the best way is to use the pictures of the teardwon for that camera: CLICK
it's surely not a repair guide (but if you look on the right side, there are 3 step-by-step guides) - but it's shows the most of the inside parts of the camera
Esta resposta foi útil?
Pontuação 2
Thanks, Marcus! I appreciate the help.
Pontuação 0
Hi
Did you ever resolve this issue. The same thing has happened to mine. I'm pretty sure it's the door latch spring.
Thanks
Stuart
Pontuação 0
Actually the U-shaped spring is the one that lets the door latch engage with the body. It is located at the right side of the Roller Assy looking from behind the camera. Observe the way it mounts on a functional camere, it´s tricky to describe in writing. The metal part it activates is visible on Step 9 of the dismantlich pictures.
Pontuação 0
Adicionar a sua resposta
kevin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 5,836
