Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
Pergunta encerrada
Formating to Mac OS Extended
Should I format to Mac OS Extended (Journaled) or Mac OS Extended (Case-sensitive, Journaled)???
Update (09/05/2015)
It's Mac OS X 10.5.4???
Update (09/05/2015)
Thanks for helping me we all appreciate it!!!;~)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This gets into file names case. As an example the file MY.TXT, My.TxT, my.TXT, my.txt would be seen as different files and all could live within the same folder if you had selected Case-Sensitive.
If you had set for the default the file MY.TXT, My.TxT, my.TXT, my.txt could not exist in the same folder as the system would treat them all as the same file. If you had tried moving one of these into the folder the OS would ask you if you want to replace the other file.
The short of this is this use the default Mac OS Extended (Journaled) ;-)
Esta resposta foi útil?
Pontuação 3
1 comentário:
This was a continuation of this question and does not really stand alone as a independent question: Finding destination for installing operating disks..
Also some comments have been deleted that I made and do not show up in the history making the conversation hard to follow.
por
Pergunta mais útil
Pontuação 3
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 113
