Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
Fickering black lines when on a phone call
Hi Guys,
Can you help with my query? I have an I Phone 4S, I cracked the screen several months ago, and used it for months like that with no problems.
I decided to get the screen replaced, so took it to a local shop to get it replaced. Since getting it fixed a new problem has appeared. When making or receiving a call,when the phone is away from my ear, I get these random black lines flickering over the screen. These lines are only present during a call, all other times, playing music, texting .watching videos etc everything is fine.
I took it back to the phone shop, they replaced the screen again, but the same problem is still there.
I have googled this fault, but there does not appear to be a solution.
Any ideas ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The ribbon cables are most likely pinched in some way. I would return the shop and demand that it be fixed. It is also possible that the FPC connectors were damaged while installing the new display.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 45
