Ir para o conteúdo principal
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
touch screen does not respond
Why does my touch screen not respond every time I touch it?
Esta é uma boa pergunta?
Pontuação 3
5 comentários
My screen has only 1 area where it doesn't responde
por
Mine similar issue just touchscreen buttons on bottom that make it so I can switch apps
por
Same issue. Amazon hopefully will send a replacement. Switch to Samsung.
por
Help my kindle fire hd won't touch anymore and it's touch screen
por
My toch screen is frozen with a yellow line around
por
Adicionar um comentário
1 resposta
Pergunta mais útil
mikecornerstone, could be a bad digitizer. Of course, you do want to try a soft reset first Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Wait a minute or two to give your device time to reboot
Turn the Kindle back on.
After that you most likely will have to replace the digitizer. Here is the guide for it
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mikecornerstone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 21,108
