Ir para o conteúdo principal
The Nabi Jr is a 5 inch learning tablet designed for pre-kindergarten and kindergarten children. Model: NABIJR-NV5B.
21 Perguntas Visualizar todos
Pergunta encerrada
Not working unless plugged into the wall
My nabi Jr got wet and now it only works if I have it plugged into the charger.. The battery icon says its 100% but when I disconnect the plug the tablet turns off. I set the tablet back to factory to try to reprogram it but nothing..
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
drenna83, open it and clean it properly with 90%+ isopropyl alcohol and a brush. After that replace the battery and re-evaluate. Use these guides to work on your Nabi Jr.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 572
