Ir para o conteúdo principal
Versão aprimorada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer chaves de fenda simples e ferramentas de alavanca. Modelo A1303 / capacidade de 8, 16 ou 32 GB / parte traseira de plástico preta ou branca.
water damage...now working, but dim display
I fell in a pond with my iPhone in my pocket, but immediately took it out (15 sec. or less), dried it off the best I could, took the Sim card out and used a hair dryer (on low heat) to dry some more. I didn't know about the rice trick then. By the way, it was still working for about 15 minutes and I didn't realize I should have powered it off. Anyway, it will now start up, however the display is extremely dim to the point of being unusable really. I have tried resetting all of the settings and did a reset by holding the home and power buttons down. No luck, as it is still the same. Any ideas would be greatly appreciated. I am wondering if a cleaning may help things or I need a part. By the way the display works fine other wise.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
similar has happened me tried lots of things no joy
por Compartilhar
does it react in any way ? try the steps i wrote and you have a chance to fix it!
por Compartilhar
Adicionar um comentário
8 respostas
Solução escolhida
fluid damages can do serious damage to the phone
there is a white/greenish residue that shortens the parts, this residue must be removed
disassemble the phone, use one of the guides from te right (you didn't wrote what iphone model you have - thats why i can't provide a direct link for that)
use isopropyl alcohol (>90%) and a soft paintbrush to carefully clean the parts, don't forget the connectors
let the phone dry - without a hair dryer
reassemble it and try to power it on
good luck
Esta resposta foi útil?
Pontuação 7
11 comentários:
Thanks, it is an iPhone 3GS and will try the advice with fingers crossed.
por Compartilhar
The phone(3gs) is fully functioning but not the back light. What u reckon
por Compartilhar
gav - did you clean it like i described it? check the lcd connectors too!
por Compartilhar
Markus thanks for the help but didnt work still have a dim screen, phone is clean and dry inside and actually enjoyed dismantling it. Any other suggestions greatly appreciated
por Compartilhar
what exactly happend with the phone?
por Compartilhar
Exibir mais 6 comentários
do i need to dismantle my iphone before putting it in a bag of rice??
Pontuação 2
2 comentários:
it will help, you also want to remember that Rice is only a first aid. You should clean the phone with isopropyl alcohol to avoid corrosion damage later on.
por Compartilhar
forget the rice, a total waste of time
por Compartilhar
will the rice still work even after its been left a few hours? or would of had to have been put in immediately for it to work?
Pontuação 1
2 comentários:
it might still work as a first aid to draw up some of the water. Again, rice does not fix electronic components.
por Compartilhar
thanks alot!
por Compartilhar
Yes, rice will work even after a while, even after days. Rice will pull the moisture out. Sometimes there is permanent damage (rice won't fix this). Sometimes there's rust or corrosion which would require cleaning. Sometimes though, the moisture just causes a short (an example is my friend's iPhone button wouldn't work... it had been weeks). If the moisture is removed, it may fix some of the problems.
FYI: Silica packets also work.
Pontuação 1
There is a coil on the mother board that powers up the display burns out due to water damage. Only way to fix this problem is to replace the 6R6 coil.
Pontuação 0
2 comentários:
sorry fluffy, that is not the right answer....:-) the coil is 6R8. There are also a few other things that one should try before replacing the coil....
por Compartilhar
Like what? What are the other things that I should try before replacing the coil?
por Compartilhar
After a phone is submerged, first dry it off, then stick it in a bag of rice overnight, maybe even for a day or two. Rice pulls the moisture out of the internals. This is why they put rice in salt shakers, to absorb the moisture.
You could use silica packets or purchase one of the specialty "emergency" bags, but rice works just as well.
Pontuação 0
My phone has been doing exactly the same thing since it was half submerged in water, but all I can recommend is leaving your phone in rice for at least 48-72 hours since it got water damaged. I've heard a few stories of people doing this and there phone working like new!
Good luck all!
Pontuação 0
Hi I need help.. . I dropped my phone A10s Samsung in water, I've put it on rice but the problem now there is no brightness on the phone it's very dimm
Pontuação 0
1 comentário:
Did you find the solution?
por Compartilhar
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 30
Ao todo: 63,809
