Ir para o conteúdo principal
O Sony Xperia Z3 é um smartphone Android lançado em 2014, conhecido pela sua longa autonomia da bateria e durabilidade.
Xperia z3 doesnt charge
Hey, my xperia z3 doesnt charge anymore. Only the red light is flashing. It has been connected for 10 hours now and i still cant turn it on. What could i do?
I tried the reset buton then volume + and power button and still nothing.
Does anyone know, what can i do?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
My sony Z3 D6603 dont turn on anymore, never charge, never power on again, and I change the battery, when I plugged in with the wall charger or computer the led powered on for a few seconds and turn of, I did the comadand power + volume up and feel a vibration but never turn on any more, How can i fix my cell phone i think the problem is in the main board
por Compartilhar
Maybe you have the complete mainboard schema to know th number of all resistance, capacitor, condencer, IC
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
-Try to change the charging cable or adapter, if can solve the problem, that's the reason of broken cable or adapter.
-Try the magnetic charging. If can charge the phone well, the problem may be caused by wrong USB port. If can't charge either, your battery may be broken and need a replacement.
- If new battery can't save your phone, you need take it to check the motherboard.
Esta resposta foi útil?
Pontuação 1
1 comentário:
por Compartilhar
has your device started working again? i am facing the same issue at the moment. please help
Pontuação 0
Adicionar a sua resposta
infoservis112 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 2,385
