How to added transmission oil
how to added transmission oil
Esta é uma boa pergunta?
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
Esta resposta foi útil?
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 38
Duração total: 17,307
