Ir para o conteúdo principal
O Sony Xperia J é, simplesmente, um smartphone que funciona com o sistema operacional Android.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Do you mean this connector?
Imagem
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Esta resposta foi útil?
Pontuação 0
The problem that you state.have different problem with mine situation
Pontuação 0
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Pontuação 0
Adicionar a sua resposta
filerzr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 33
Ao todo: 3,205
