Ir para o conteúdo principal
O Samsung NaviBot SR8855 é um aspirador autônomo prático da Samsung.
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
I have the same issue. Is there a fix?
por
Adicionar um comentário
5 respostas
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
Esta resposta foi útil?
Pontuação 0
Can you describe more precise what did you done?
Could be the aging of the accumulator?
Pontuação 0
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
Pontuação 0
1 comentário:
Hi
What voltage do you use in capacitors?
por
Can be that the battery started to decay?
Pontuação 0
It could probably have an effect but it is not a reason.
Pontuação 0
Adicionar a sua resposta
smsoftware será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 2,310
