PC no longer lights
Good evening to you;
I have a problem with my HP G62 notebook, it does not light up although it normal load but do not want to turn on, so I decided to disassemble this motherboard to see if it is not a fuse is not burned, but I do not know where is a fuse on this motherboard
Can you help me find a fuse on this motherboard?
Thank you
Update
when I press the power button does not light up
Esta é uma boa pergunta?
Have you checked your power supply for proper voltage out? Have you checked your DC jack? Have you checked your battery? What model is your motherboard? Post the numbers from your motherboard with your question
por oldturkey03
