Ir para o conteúdo principal
O Nokia Lumia 630/635 foi lançado em junho de 2014. Identificado pelo modelo 635.
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Pergunta mais útil
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
Esta resposta foi útil?
Pontuação 1
1 comentário:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
por
lumia 635 power baton bord not warking
Pontuação 0
Adicionar a sua resposta
gobstopper2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 1,343
