Unstable Take-off and crash
Hi, initially when I hit the take-off button the drone used to hover. For some reason now it spins and tilts to the right ...and crash lands
Esta é uma boa pergunta?
Verify your helices, My do the same and I change, be attencion on the jelices open in the center and others is not, the close ones maybe put in silver pin above.
Sorry about my english
Esta resposta foi útil?
André, o que vc fez pra resolver o seu? O meu não fica mais parado, ele fica andando sozinho...
calibrated wrong if the trim is out of wack it will do that
How do you fix the trim?
Did you ever fix your problem? Dealing with the same thing. I was flying my drone when the prop flew off and now it does not take off and hover at all
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 2,496
