Ir para o conteúdo principal
A Nikon D90 é uma câmera DSLR de 12,3 MP capaz de tirar fotos e gravar vídeos.
menu button not working
I can take a picture,but none of the camera buttons are working.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Is it just the buttons on the back, or also the ones on the top, front, and side?
If it’s just the back, it could be just the cable that connects the back buttons to the mainboard that has come loose, or has become faulty. You could try opening up the camera and when removing the back check the ribbon cables, and could even just need to reseat them in the connectors to get them working again.
If it is all the buttons all over the camera, then sadly, it is likely the mainboard that is faulty.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Don será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 742
