MacBook Water Damage Repair
Hi,
I've got a water-damaged 2012 15" Macbook Pro Retina. It doesn't do anything when you try and power it on, but it does seem to accept charge when you plug the magsafe charger in, as the orange light comes on.
I've seen replacement logic boards on ebay and tempted to try and fix it. Does anyone have any advice before I buy the replacement board? I dont want to spend £350+ on a logic board in case it doesnt fix the problem, or somehow damage the new board when re-powering up the laptop.
Thanks,
Scott
Esta é uma boa pergunta?
Where was the liquid spilled? On the bottom, keyboard, or somewhere else?
por chriswku03
From underneath, through the side cooling vents
por ifonlyilistened2
without the ability to repair the board. You wont have much option other than replacing the board. You could open it and look for corrosion and try cleaning it with 99% rubbing alcohol and a soft brush.
por chriswku03
Already tried to clean the board with rubbing alcohol, but it didnt work. If I buy a replacement board and fit it, is there any risk of blowing the new board when I power it up? Also, is there likely to be any damage to the screen etc, or should the board replacement fix the issue?
Only chance of doing damage again with a new board would be if you have damaged parts other than the board.
por chriswku03
