Ir para o conteúdo principal
O eMac foi um computador Mac com processador G4 tudo-em-um, projetado para o mercado educacional e lançado em abril de 2002. Foi o último Mac a usar uma tela CRT e foi vendido a um preço acessível para escolas e outras instituições.
Am I using the wrong ethernet cable?
when using an average ethernet cable,emac
won't recognize it.
Will the Belkin RJ45 FastCAT™ 5e Patch Cable, Snagless Molded Cable fix my problem?
Also, is there a way to upgrade the 1.1 usb ports with 2.0 usb?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
First thing you should do is just try any other ethernet cable, to rule out a bad cable. Ether cables are fairly delicate and shouldn't be bent too sharply. Are you seeing "No cable connected" in the Network control panel? If you still get this message with a different, known-good cable, then your Ether port might be toast, but first you should try zapping the PRAM, resetting the NVRAM, and booting to a different system, to rule out software.
If your port appears to have died (I've had this happen a few times) you can get a USB-Ethernet adapter like this one: http://eshop.macsales.com/item/Macally/A...
Of course, first check ifixit to see if they have something like it!
Zap PRAM: reboot while holding down command, option, P, R. Keep holding down till you hear 3 chimes.
Reset NVRAM: hold down command, option, the letter O, and F. You'll get a while screen with black text. Type "reset-nvram" and Return. Type "reset-all" at which point the computer will reboot automatically.
Esta resposta foi útil?
Pontuação 3
NO and
NO
Re the cable, what are you connecting to, you may need a crossover cable?
Pontuação -1
5 comentários:
Macs since a long time back don't need crossover cables; they can sense what's needed and deal with it internally.
por
A cross-over cable would be used to connect like devices (eg. 2 hosts, a desktop to a laptop). Straight-through cables are used to connect different devices, such as a host to a router.
You may want to check up on your answers before posting.
por
Many recent Macs, including all Intel Macs, do not require crossover cables. See http://support.apple.com/kb/HT2274. As for this eMac, if it's ATI graphics or later, it does not require a crossover cable; they have Auto-MDIX, which automatically configures the ethernet connection. The OP does not say what they are trying to connect to, as you correctly point out, but one can presume it's a hub, switch, or router, as that's the most common scenario.
por
Still, the probably scenario (unlike devices), a straight through, the most common type of ethernet cable, is the needed one.
por
AKA a patch cable.
por
Adicionar a sua resposta
Celeste será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 2,924
