Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Perguntas Visualizar todos
My mag safe does not work any more :(
for some reason my charger does not charge the mb.... it cannot power the machine... or charge the battery...
i have replaced the AC adapter brand new from mac... the plug that plugs to the power and the mac
so now i have question do you think its the internal piece? the dc adapter on the motherboard? what else can it be?
Update
well ... i just replaced this part... replaced AC adapter... what else can it be???
battery still not charging :(
Update
I replaced the DC-IN Board... still does same thing...
Esta é uma boa pergunta?
Pontuação 2
2 comentários
test it out with a multimeter and trace the current from the magsafe port and work inward.
por
If your machine has suffered some type of accident, it's best you disclose that info in order to better help you.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
This is the part that you most likely have to replace. If you hurry, iFixit has ONE in stock. Did u have an accident? Water damage? Fall?
Update
I would look into the Battery connection to the LogicBoard. You never answered my question: what happened to the Mac? what caused these symptoms??
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ agreed
por
I have the same situation and I think its the logic board. Does anyone know how to fix it? In my case charger is flashing green so there must be a shortage. I am sure I could fix it, just dont know where to look.
Pontuação 0
1 comentário:
Please start your own question, you have a better chance of getting helped this way. Or if you have input or ideas, just leave a comment.
por
well... I gave my laptop to private mac repair place... they can use my warranty to get my new logic board , I should know everything is good by wed's :)
Pontuação 0
Adicionar a sua resposta
michael kos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 3,620
