How do I re-attach the bezel to the rear panel?
Theres a gap between the bezel and the rear panel, how do I fix this ?
thank you
David
Esta é uma boa pergunta?
thank you
David
the only way to get this done, is to disassemble the phone, fix it and reassemble it.
use the rear panel guide - the bezel is pretty much the last part you can remove on the iphone - so getting to it means, removing everything.
good luck with that
Esta resposta foi útil?
If your back panel is all jacked-up you may want to replace it.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,226
