Why no charging the my bathery
why its no charging the my bathery
Esta é uma boa pergunta?
nagylevente20, there are a few possibilities. Check to make sure that your cable and charger are working. Next check your charging port, look for any loose or broken pins. After that replace the battery. Then re-evaluate. If it is still not working, you could have some issues with the charging circuit on your logic board. Start with the easy stuff first. Here is the guide for your battery.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 680
