Ir para o conteúdo principal
Fan always going how to fix
My fans on my macbook air won't stop turning. They have not switched off unless I shut down the laptop or closed it. Its not over heating, the CPU is 0% and I have tried everything and nothing is working!!
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Why/when/how did this issue arise?
por
Why you want stop turning fans? They must cooling down laptop its okay, or its to loud for you?
por
Adicionar um comentário
1 resposta
The temperature sensor may be faulty ? Try installing a Fan Management App.
http://www.macupdate.com/app/mac/23049/s...
This will give you control of your fan speed but more importantly the temperature of your CPU.
Maybe it just needs a good cleaning to ensure it's cooling down properly.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Unfortunately Fan temperature is OK. Apple Genius ran some tests and also didn't find any problem. I tried to clean it inside and still no result.
por
Adicionar a sua resposta
moxno será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,434
