Ir para o conteúdo principal
A segunda geração do HTC One—chamada de HTC One (M8)—apresenta flash duplo e a nova interface Sense 6, tendo sido lançada em 25 de março de 2014.
Power button not working.
Hi, my girls phone recently started doing this weird thing where it appears that the power button is being pressed down even though the button isn't being press or stuck in the pressed position. I order a replacement part, the daughter board that has the power button on it and after I did it appeared to be working correctly. Then about a day or so later the power button stopped working all together. Not sure what the issue might be other than a bad part but I find it strange that it was working and then just went out all together.
Esta é uma boa pergunta?
Pontuação 7
1 comentário
Same thing happened to me but it started after a phone call right after I got off of the phone I was going to try wiping it completely to see if that works it definitely has to be something in the programming because the phone didn't get damaged
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Get cocoa butter or like kind of a grease on your fingers and attempt to access apps and do regular things on your phone and it'll stop it'll do it every now and then but rarely. Also there's the power off apps if that doesn't work
Esta resposta foi útil?
Pontuação 1
The only prob here is just the replacement but i advice u to send to some phone service
Pontuação 0
1 comentário:
Its all about power button
por
on off battun not werke
Pontuação 0
There are multiple ways you can replicate the functionality of your power button in case yours doesn’t work anymore. Here I will tell you about the only two methods, excluding the obvious other one – having it repaired: turning your phone on and off with the help of apps and a neat little piece of hardware to help you do the same.
Pontuação 0
1 comentário:
Well, tell us then ...
por
power key not working??
Pontuação 0
Adicionar a sua resposta
cdude78411 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 21,950
