Ir para o conteúdo principal
Lançado online em 16 de janeiro de 2009, o Inspiron 1545 é um notebook econômico de 15,6" disponível com 3 ou 4 GB de RAM. Ele sucedeu o Inspiron 1525.
Will not load windows
Windows 7 will not load
Esta é uma boa pergunta?
Pontuação 3
5 comentários:
Have you tried safe mode? what have you tried?
por
Be more specific, please. Give as many details as you can so anybody can help you.
For example, tell us, Does the laptop turns on? Can you see the Dell logo screen?
por
Mine loads to CRPdsk.sys and then crashes out and will not boot with original disk it came with containing Vista PREMIUM or any recovery processes.
por
I ran diagnostics and everything in the system passed; tried backing up to earlier time to no avail. I have re-seated the RAM. I tried to run it on only the 1st stick of RAM. Tried recovery, chkdsk, scan etc. nothing. It just blue screens out at that same place - sorry think it crcdsk.sys not crp!
por
Also tried safe mode and everything under that menu.
por
Adicionar um comentário
1 resposta
Dell Inspiron 1545 boot loop....
I ran diagnostics and everything in the system passed; tried to reload hdd with new os... system came back with the error code that no drive was loaded. (Basically could not read the hdd). Replaced the HDD with a new 250 GB HDD and tried to load OS, same issue. I have re-seated the RAM also. I tried to run it on only the 1st stick of RAM. Next attempt I will try to load the OS with 1 stick of RAM, but I do not think it will work. I am open to any other suggestions that anyone has. I am fixing this pc for a co worker and was not wanting to take it all the way apart, but I will if necessary? Suggestions Please...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
strugalamartin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 34
Ao todo: 924
