Ir para o conteúdo principal
O HTC Desire 816 possui uma tela de 5,5 polegadas com resolução de 1280x720, câmera traseira de 13 MP e tecnologia HTC BoomSound.
Right side heaphone jack not working
The desire 816's jack doesn't seem super solid in the first place. However, my 816 fell on a hard floor and now when I plug in any headphones to the jack, the right side earphone doesn't work. This seems like an internal issue in the phone. Wonder if you all have any solution! Thanks!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
i have this too
por
Connect the headphones to another device and check if they work properly. They probably won't because if the headphones Jack would have been not working then neither of them would have been working.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
You may have to replace head phone connector
Esta resposta foi útil?
Pontuação 1
It looks like your head phone jack is failing. The head phone jack consists of spring loaded contacts and due to the impact it may have been bent out of place. It may be possible to bend the contact spring back to place however, if this does not work the only solution would be to replace the headphone jack completely.
Pontuação 0
First of all you need to go to the htc service center and ask them to change the earphone jack.
Pontuação 0
Adicionar a sua resposta
Ryam Green será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 564
