iPhone 5S Lightning cable assembly
Hi, I have an iPhone 5S model A1533 white. I purchased a lightning cable assembly and have removed the old one, however the new one looks a bit different from the old. I am attaching two pictures.
...I'll try and explain. If you look at both pictures just to the right of the lightning port and a bit up you'll notice some differences between the two....Also should I remove the red backing on the new assembly. I'm assuming there is a sticky type material which will replace the adhesive on the old assembly. I can be reached at 203.524.9156 or email at pjg1600@yahoo.com....thanks, Jeff
Esta é uma boa pergunta?
