Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5S Lightning cable assembly
Hi, I have an iPhone 5S model A1533 white. I purchased a lightning cable assembly and have removed the old one, however the new one looks a bit different from the old. I am attaching two pictures.
...I'll try and explain. If you look at both pictures just to the right of the lightning port and a bit up you'll notice some differences between the two....Also should I remove the red backing on the new assembly. I'm assuming there is a sticky type material which will replace the adhesive on the old assembly. I can be reached at 203.524.9156 or email at pjg1600@yahoo.com....thanks, Jeff
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
You are going to need to carefully transfer the metal clips, black tape and mic cover over to the new one. And yes , the red tabs have adhesive underneath.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thanks Brian, this appears to be a major step and not all that easy... I'm surprised it is not included in the step by step instruction
por
Also I don't see how the mic cover can be removed from the old assembly
por
I just figured out the mic cover...thanks
por
One final question, is it necessary to apply some adhesive to the old metal clip to hold the new piece which I believe is associated with the touch id sensor?
por
If there is no adhesive left on the clip after removal , then yes add a small dab.
por
Adicionar a sua resposta
pjg1600 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 138
