Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36472 Perguntas Visualizar todos
Soldering U2 (what tools needed?)
Hello everyone,
I would like to start micro soldering, i have phone compagny but sometime we broke some chip during repair.
What is all tool needed for remove U2 chip and replace with new one ( i already have the new U2)
Can someone explain me how to desoldering and how to soldering back, which method is the best ?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Hey,
You'll need to start off by getting a good soldering iron, something along the lines of a Hakko, then you will need decent flux, and decent solder at different widths, for smaller stuff go with the thinner soldering wire, try and make sure it's multicore solder as that also contains flux in the solder and helps a lot. A good reflow station will be needed for sure. You will definitely need a decent microscope to, you can't do it by eye, as the chips are so tiny! If you do plan on soldering a lot, you'll more than likely need a fume extractor, as the fumes from soldering are bad for health.
Hope this has helped. :)
Esta resposta foi útil?
Pontuação 3
Tools only:
Hotairstation/Reworkstation
Soldering Iron
Solder
Flux
fine quality tweezers (also important)
Changing the u2 chip is one of the easier IC's to change but still not the place to learn micro soldering.
Practise and get to know your tools on dead boards until you know how to remove parts without destroying the whole board.
Pontuação 1
PPD120E or good soldering iron
Pontuação 0
Adicionar a sua resposta
Phonetech93 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,064
