Ir para o conteúdo principal
Smartphone de segunda geração lançado em novembro de 2012. Disponível nas cores preto furtivo (stealth black) ou branco polar (polar white) / 32 ou 64 GB / cartão micro SIM / sem slot para cartão SD. Modelo #PM63100
Accidental screen damage due to fire
Hey. Recently, I had a kitchen accident involving my phone. I switched on a baking oven without realizing that my phone was inside. I adjusted the burner to 350 degrees Fahrenheit. About 15 seconds later, I realized that my phone was inside!! I shut off the burner and retrieved the phone. The right half of the screen was completely black and the phone was very hot. Slowly however, the blackness started to go away and the phone cooled down. Luckily, it operates normally except for two things: the pictures from the front camera are a bit hazy; and, there is some fading on the right side of the screen.
Now, to my question. What can I do to fix the screen? Should I replace it? If I don't, could the fading spread or become more intense?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
In order to replace your screen use this guide, however given your description of the "hazy camera" you may have some issues other then the screen fading, in that case go seek professional help from a local repair shop in your area.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Farooq será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 319
