Ir para o conteúdo principal
O drone possui Wi-Fi e está equipado com uma câmera HD integrada. Ele é usado para tirar fotos e filmar. Número do modelo: PF722000
Bebop drone - Camera front glass
Hello.
I have scrached the grass of the camera (bebop drone). Is there a way to change the glass? This product (EPP nose) doesn't contain glass? I mean... the glass in front of the bebop is the camera glass without any protection?
Thanks a lot
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
5 respostas
Pergunta mais útil
You can try this:
http://chtech.co.za/wordpress/parrot-beb...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Please can you contact me at harrisonashley8357@gmail.com thankyou regarding your diy lens
por
Check out this: https://www.youtube.com/watch?v=uyO5qx81...
I haven't tried it yet, but need too. I scratched the lens of my Bebop as well, but don't need to replace the entire camera. I hope iFixit can source the replacement lens for us: that would make life a LOT easier!!!!
- Jeff
Pontuação 0
The result is in focus but one can clearly see the effect of the lack of anti-glare coating.
Pontuação 0
My front broke can it be replaced
Pontuação 0
If it’s out of focus than it’s easy fix; all you’ll need to do is to watch YouTube video.
but sometimes the camera itself is broken & if you attempt to turn on your Bebop that all it gives you is Blinking green light & nothing else.
to fix this problem all you’ll need to do is to watch another YouTube video while you remove the front Nose, remove the Camera housing, than disconnect it from the MotherBoard; Screw it back together & you’ll have a working Drone without the FVP(Camera view) but you can still fly it whiteout any problems.
All Thanks to parrot.com to have &&^&@@ us all; They manufacture Bebop Camera Replacement but for $300+ that they can go stick their heads up their ass, as I’m sure by now it’s the exact fit.
Pontuação 0
Adicionar a sua resposta
cinepallas2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 9,840
