Ir para o conteúdo principal
Uma piscina é um recipiente cheio de água destinado à natação ou recreação aquática.
Salt Chlorinator Cell Repair
I want to find out how to repair a Salt Chlorinator Cell? It's a seemingly sealed unit with two electrodes inside which convert salt to chlorine. These electrodes get worn out or used up over time. Can these be replaced or replated? Any special tricks and things to know? Anything to be aware of so as not to mess things up? What's the worst that could happen?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
What make and model? Post some images with your question so we can see what it looks like and can may be come up with an idea.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Most cells can be replaced every 4-5 years. Get out the install manual, it should tell you how to tear down and get a new cell that matches your model, easy fix. Get a zinc anode to help with corrosion problem, it attracts the Na ions instead of all metal parts, easy to install on ladder or plumbing and will help prolong your cell...35 years in pool biz
Esta resposta foi útil?
Pontuação 3
2 comentários:
Great idea about using a sacrificial zinc. I will be getting one for myself soon thanks.
por Compartilhar
Cyndi - are you a sailor by chance? This is how they save ships ;-)
por Compartilhar
Hi!
I am also looking for a solution. Take a look at this:
http://www.philipdoolittle.com/2018/03/s...
I have 2 dead cells that I will open soon. With 2 may be I will get enough good plates to make one. My main concern is what material should I use if I have to rebuild a conneting post and how to fix it to the plate?
Richard
Pontuação 0
2 comentários:
Hi Richard,
The link domain appears to be dead.
Do you have any info and how did you go with rebuild.
Likewise I have bits but not yet sure how to connect. Spot Weld?
Brett
por Compartilhar
considering this myself, looking to source metal plates
desmetde@gmail.........com
por Compartilhar
Adicionar a sua resposta
Daniel Rudewig será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 41
Ao todo: 9,597
