Ir para o conteúdo principal
2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
Why is my display has a vertical line
why is the display has vertical line
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Bernard Jones, if it is a single vertical line, it most likely is a bad binding (TAB) error on the LCD. Of course you do want to make sure that the cables are properly seated, but my first choice is a bad LCD panel.
Esta resposta foi útil?
Pontuação 1
LCD panel. To crush any hopes and dreams of it being the cable, before someone chimes in that it uses the cable, be reminded that displayport is a works-or-doesn't-work protocol. It isn't like LVDS which is based on difference between lines. It's the LCD.
Pontuação 1
Adicionar a sua resposta
Bernard Jones será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,545
