Ir para o conteúdo principal
The JBL Charge was released in 2012. It features Bluetooth and 3.5mm audio for a wide range of inputs. A high-capacity 6000mAh battery provides several hours of entertainment and can charge other devices with its built-in USB port. Available in Black, Green, Gray, and Blue.
28 Perguntas Visualizar todos
Pergunta encerrada
Is the JBL Charge waterproof?
I want to use the Charge at a pool party. The device description written says that the device is durable and built for outdoor activities, so I am curious if it will function in a pool setting.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The device is not waterproof. It will fail to function when in a pool, but it should work in light rainfall. If the device is exposed to water damage, refer to the Troubleshooting page.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,053
