Ir para o conteúdo principal
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
56 Perguntas Visualizar todos
Want to know how the Status light wired for Time Capsule A1470
I'd received damaged AirPort Time Capsule A1470. The status light's 3 electrical wires and 3 pin connector were cut. The only "3 wires" are left inside. I wanna know how those wires connected to the logicboard.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
They connect to the logic board J1700 connector which is just to the right side of the power supply connector. Here's a good picture of the connectors: Step 4 image from this teardown: AirPort Extreme A1521 Teardown which is it twin without the hard drive.
Esta resposta foi útil?
Pontuação 1
1 comentário:
On my Airport Extreme, the pin closest to the J1700 lable is common to the status LED, the middle pin is to the yellow and the farthest from the J1700 lable is t the green.
por
Adicionar a sua resposta
Mai Ichijoh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 307
