Ir para o conteúdo principal
A Makita angle grinder released in June of 2010. Model number GA4030K.
What is causing my angle grinder to make so much noise?
For the past several days I have been using my Makita GA4030 to work on an extensive project for many hours at a time. As I was using it this afternoon I noticed that the grinder started making a funny noise that it has never made before. What’s going on? Is this something worth fixing or should I just go buy a new one?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
When you dropped the angle grinder, you may have dislodged or broken some internal components. To find the problem, open up the angle grinder and look for damage and loose pieces. Damage could take the form of dents, unconnected wires, or loose graphite bits within the device.
The angle grinder is fixable - visit the ‘switch repair’ link on the troubleshooting page found here:
Makita GA4030K Troubleshooting
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nyssa Backes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 4,430
