Ir para o conteúdo principal
Cradle Audio System with separate subwoofer. Sony's first speaker system with integrated iPod dock.
3 Perguntas Visualizar todos
Why is my speaker making a weird noise?
When I try to play music, the speakers make a buzzing noise. It does this both when using an iPod and when using the auxiliary cord. What should I do to fix this?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
The most likely cause of this problem is that one of your speakers is blown. You now need to determine which speaker is blown. Play music through the speakers and try to listen to one side at a time to determine if it is the left or right speaker.
If you want to double check that you picked the broken speaker, remove that speaker and play music again. If the sound seems clear, you chose the correct speaker.
Follow this guide for step by step instructions to replace the blown speaker, or check out the troubleshooting page for further help.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Sarah Means será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,432
