Ir para o conteúdo principal
O Lenovo ThinkPad T500 é um notebook corporativo lançado em julho de 2008. Este notebook de 15,4″ pode ser configurado com processadores que variam desde o Intel Core 2 Duo P8400 de 2,26 GHz até o modelo de alto desempenho Intel Core 2 Duo T9600 de 2,8 GHz (ou Core 2 Extreme de 3,06 GHz), e conta com gráficos integrados Intel ou gráficos comutáveis ATI.
Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
Esta resposta foi útil?
Pontuação 3
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
http://gadgetwise.blogs.nytimes.com/2009...
Pontuação 0
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
Lenovo ThinkPad T500 Troubleshooting
Pontuação 0
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
Pontuação 0
1 comentário:
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
por
Adicionar a sua resposta
Nickie Gurney será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 7,202
