Ir para o conteúdo principal
Pergunta encerrada
glass broken. All else works fine
can I change out just the glass or do I need the Assy.?
The glass is less than $10 and the Assy. Is just under $100
On the repair here. It doesn't show info on the LCD removal.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Jetfixer, sure you can. All you need is an LCD separator and a OCA vacuum laminator and a few other tools. As you can see, unless you have the tools and the experience, I suggest that you replace the complete assembly. Cheapest way to go is to actually let Apple do it for $109.
Esta resposta foi útil?
Pontuação 1
of couse you can, but the installation of any new part should be done by a qualified person.
Pontuação 0
1 comentário:
I'm sorry. I was under the assumption we should be able to fix our own stuff. Just looking for a little insight.
por
you can change the glass lens by yourself. v
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 160
