Ir para o conteúdo principal
O primeiro tablet da família Acer Iconia Tab B1, o Acer Iconia Tab B1-A71, foi anunciado em janeiro de 2013.
screen goes completely white
I purchased my Acer Iconia B1-730HD-17A4 7-Inch HD Tablet with Intel Atom processor 5 months ago. Worked great until recently. My screen will all of a sudden start going white in the corners then gradually the entire screen goes white. I have to click the on button to get it working but then it fades out again. This happens indoors or outside, so not a hot\cold sensitivity issue. Very frustrating. Whats causing this?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Try this first;
1. With the tab off,Press Vol-up and Power
2. If display goes on: Release power but hold vol-up
2. Toggle Lock screen switch (On>Off>On>Off)
This will make the tab go thought the factory reset protocol.
If it doesn't work, you probably have a bad display, nothing much to do, you've got to change it.
Esta resposta foi útil?
Pontuação 0
1 comentário:
without change we have no option???
por
its not working... i will try it but vain nothing is shown on my screen more then a spark white and black...its furstated... :/
Pontuação 0
Adicionar a sua resposta
bjsmom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 1,684
