Ir para o conteúdo principal
O Huawei Ascend P7 é um smartphone de 5" lançado pela Huawei em junho de 2014. Números de modelo: P7-L10, P7-L00.
No Service No network
Hello.
My phone has been off for 2 days, fully charged it. and when i switch it on it ready no service... Cannot make calls nothing. Re-started still noting did Factory reset.. Still nothing.
Please help!!!
Thanks
Esta é uma boa pergunta?
Pontuação 57
9 comentários
My phones signal is gone for a while now
por Compartilhar
my mate7 has 1 month no signal, please help.
por Compartilhar
My Huawei honor p7i network is nt working please how do I do please help me out
por Compartilhar
My huawei phone is falling in the "no service "
How to relieve this
por Compartilhar
I just order a huawei honour 5 I install a sim but no signals
por Compartilhar
Exibir mais 4 comentários
Adicionar um comentário
31 respostas
Pergunta mais útil
1) check the SIM card is working properly
2) Check with your operator whether your IMEI blacklisted or not
3) update the firmware if available via OTA
4) Change the network mode : GSM only if signal comes change the network mode to 3G only if you found same issue the one of transceiver not working properly
Esta resposta foi útil?
Pontuação 14
5 comentários:
It wasnt helpful but the tranciever bit how do I fix it myself
por Compartilhar
How you did that my honor 9 its the some problem pleas
por Compartilhar
i have huawei honor 5x..sim its ok can detect,no problem..but signal no services..why yaa.. plis help me..
por Compartilhar
Sir
My mobile can not show the Sim he show no service plz help me my mobile y 7 prime 2019
por Compartilhar
I'm using Huawei Y5 2019 I've been struggling with network problems, it says cellular network is unavailable, try using wireless network to make a call
por Compartilhar
huawei p7 wifi not working
Pontuação 5
3 comentários:
Huawei p6 mobile network not working
por Compartilhar
Does your sims cards working please
por Compartilhar
I have Huawei y7 had network issues, I could not access internet, I just removed data saver and I was back,what I don't understand out of nowhere my phone started to have irritating issues NO NETWORK, I hope the magic works on you, next time I will definitely get another brand, I tend to believe Huawei phones are not reliable to its users
por Compartilhar
Pontuação 5
1 comentário:
vai no Service network my mobile huawei scl-u31
por Compartilhar
mobile network not available in huawei mobile
i have huawei honor 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Network options is also missing in phone now.
Please help me. i just bought few days before.
i am very Sad :(
should i sale it :(
Pontuação 3
2 comentários:
Same problem huawei p8lite
por Compartilhar
Same problem
por Compartilhar
I have a Huawei Ascend phone. was on a call yesterday and reception cut out no reception since in christchurch nz middle of the city!
Pontuação 2
Huawei Ascend G700 no network
Pontuação 1
i have huawei honour 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. I removed water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Pontuação 1
Huaweiy330-u11 when inserted SIM it say emergencycall how to fix this problem ?
Pontuação 1
Try to turn on airplane mode, then turn it off. It helps me when i lose network signal
Pontuação 1
Network wcdma not work
Pontuação 1
how can i do how can ido
Pontuação 1
Huawei p20 lite no service
Pontuação 1
Huawei Mobile IC network is default
Pontuação 1
i got lycamobile sim card
when i put in on my phone called huawei p6
and when i want call some in said no service but for anther phone he does work but on huawei not why please help
what can i do make it work
Pontuação 0
huawei p8 lite no net appear after ten days i try all options no hope
Pontuação 0
1 comentário:
no net work shown i restart many times i remove sim many times ...still the same pls your help it's ten days back parched >>
por Compartilhar
no service max mobile 424 model
Pontuação 0
My sim app is no long in my huawei so I don't have any sim setting it says only emergency calls only and I don't have any network show in my phone ?
Pontuação 0
How to set Sim menagement?
Pontuação 0
I Have This Problem Too
Pontuação 0
honor v9 no service how to this problam fix
Pontuação 0
Remove sim n put it back.
Pontuação 0
try hard reset if nothing's happen is the problem of your cellphone is crystal ic or antenna
Pontuação 0
Falling in water and when on then no service its taking Sim but no signal
Pontuação 0
1 comentário:
i have this problem too
por Compartilhar
How do I get my new handset working it isn’t reading
Update (04/06/2019)
I just brought a phone it’s not reading my network or service rovider
Pontuação 0
Mate 20 lite Huawei no service :'( android 9.1.0.225
Pontuação 0
my huawei 3i fall into water when it fix it comes another problem no service appears i can't use it anymore i tried all the recommended steps but it didn't work please help
Pontuação 0
how to fix no service for huawei y7 prime 2019
Pontuação 0
2 comentários:
please help me with this
por Compartilhar
to my email yasirbofa@gmail.com
por Compartilhar
Network is not working
Pontuação 0
When my phone is no service Huawei nova 8i how can i do?.
Pontuação 0
How can i do about myself
Pontuação 0
No my phone yesterday will be damping in whater after fixed my phone cam no service even put sim card
Pontuação 0
Adicionar a sua resposta
muzithembekwayo88 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 116,090
