Ir para o conteúdo principal
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
Why is my cursor not flashing?
My cursor will not flash. When I hold the 2nd function button it will flash but no other keys will work.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This could either be a software error or hardware error.
If it’s a software error, try to perform a RAM reset by removing the batteries (including the backup battery) then reinserting them.
If that doesn’t help, try to reinstall the OS. This is more complicated so I’ll refer you to a video tutorial here.
If neither solution worked, refer to this guide for some hardware troubleshooting and fixes
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
adianbailey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 1,965
