Ir para o conteúdo principal
The Axess TA2513-10WT is a 10-Inch dual core Android tablet.
Why wont my tablet turn on?
The tablet will not respond or show any signs of turning on.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Faulty Power Adapter
Check to make sure the power adapter is plugged into the wall completely. If it is, make sure the light on the adapter is on. If the adapter light is not on but it is plugged in, this likely indicates that the adapter is faulty. Consider purchasing a new power adapter.
Faulty Battery
If the adapter is still working, check to make sure the charger is plugged into the tablet completely. If the tablet will turn on with the adapter plugged in but not while unplugged, regardless of charging time, the battery is faulty. Follow this guide to replace the battery.
Source: Axess TA2513-10WT Troubleshooting
Esta resposta foi útil?
Pontuação 0
Faulty Battery
Pontuação 0
Adicionar a sua resposta
Hayley Rabe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 376
