Ir para o conteúdo principal
O Acer Iconia One 7 é um tablet lançado em abril de 2014. O Iconia One 7 é um pacote compacto repleto de diversão multimídia. Com uma tela maior que a de um tablefone, clara e colorida, você obtém uma resposta rápida e horas de autonomia da bateria para manter tudo funcionando. Também incluímos a nossa plataforma Kids Center, com muito conteúdo infantil legal que os pais podem controlar.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
Esta resposta foi útil?
Pontuação 1
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
Pontuação 0
5 comentários:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
por
Nop. Problem still remains.
por
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
por
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
por
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
por
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
Pontuação 0
I wanna ask on what button should I select to organize my apps?? Thank you
Pontuação 0
Adicionar a sua resposta
ricartengenheiro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Ao todo: 2,480
