Ir para o conteúdo principal
Identificável pelo número de modelo S7562, o Galaxy S Duos é um smartphone com suporte a dois cartões SIM fabricado pela Samsung.
My touch screen is not working
my samsung galaxy s duos touch not working what shall i do ?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
did it stop responding after a drop or were you just using it and it stopped?
por
Adicionar um comentário
1 resposta
Solução escolhida
I would do the following before considering a screen replacement.
  • Restart the phone
  • Inspect the cable, the cable should be accessible without unscrewing the back. Remove the back case and on the upper left corner you will see a plastic piece with a little slit that you can pry open. Remove the battery, pop that chamber open, and disconnect the cable and look for signs of damage or corrosion. If you clean the cable or no signs of damage are evident then you may need to replace the LCD/Digitizer.
If the issue happened after the unit was dropped then more or less it may have suffered damage and the digitizer is affected.
Good Luck
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
awabdehw será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 1,961
