Ir para o conteúdo principal
Audiovox T752 7" Android tablet. Released October 2013.
5 Perguntas Visualizar todos
Why is my battery dying so quickly?
Why is my battery dying so quickly? It used to have such good battery life, now it's dying so quickly. Please help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
There are several reasons why this could be happening. First, if your tablet is a bit older, it may be as simple as the fact that the battery is nearing the end of it's life. Secondly, you may just be running too many programs at once, which would have a negative effect on battery life. You could check out guide HERE for more info on that.
A few other suggestions would be to lower the brightness of your screen or check for a battery saving app on the app store to help you out. Hope this helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Javier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 163
