Ir para o conteúdo principal
O quinto smartphone Google Nexus. Anunciado oficialmente em 31 de outubro de 2013, ele ostenta uma tela 1080p de 4,95", um processador Snapdragon de 2,26 GHz e suporte a LTE. Equipado com Android 4.4.2, KITKAT. Fabricado pela LG.
Rear camera not detected
A few weeks ago the rear camera stopped working on my Nexus 5. I tried several resets (both soft and hard) and even flashing older system images, to no avail (ironically, after a hard reset and an image flash the camera app disappears).
I decided to buy a new camera module to see if that would fix it. Now, with that installed, I managed to get the camera app back up, but it says that there is no rear facing camera on the device. As a note, the front facing camera still works perfectly.
I've double checked the connections multiple times and the camera module is connected solidly.
Has anyone else encountered this issue before? And, is it possible I just got a bad camera module or do you think I would need to replace the whole logic board?
Thanks!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
I have the exact same problem. Only exception is when I installed a new camera I couldn't get the camera app back. However if I access the camera through hangouts, then the front facing one works.
Esta resposta foi útil?
Pontuação 0
That's exactly how mine works. No amount of hard-resets or flashing causes the camera app to come back. I only have access to the front camera.
Pontuação 0
Bonjour,
J’ai exactement le même problème.
Avez-vous trouvé une solution ?
Cordialement,
Bernard
Pontuação 0
Adicionar a sua resposta
Ashley McKay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,403
