Ir para o conteúdo principal
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Perguntas Visualizar todos
What is my password?
I bought a used SSD. After I installed it, I started the computer. The computer started nicely and went to the log-in page. This page showed an account named "Home" and asked for my password. As I say, this is a used SSD. How do I find the password?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
por
The last four characters of the serial number are not digits, but letters: "DJYC."
por
Adicionar um comentário
3 respostas
Solução escolhida
I called iFixit. The clerk gave me an easier solution: start up while holding "Command R." That takes me to Disk Utility, where I erased the hard drive and restored from my backup.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Happy to hear that worked!
por
Pergunta mais útil
You probably need to reformat the drive. Do this in Target Mode or use a universal adapter. Universal Drive Adapter
Imagem de Universal Drive Adapter
Produto
$24.99
Pontuação 2
4 comentários:
Mayer, remember these drives are M.2 SSD's. I don't think the universal adapter will work here.
por
Dan, yes and no. He didn't tell us which MBA he has, so it could even be using a ZIF drive. If an SSD drive goes in, then I would guess it has a 2.5".
por
Good point Mayer! I keep forgetting the first version had a ZIF micro drive.
por
Sadly it's a M.2 blade SSD. The other option here is to mount it in this case: Envoy USB case. I also like Mayer's idea of Target Mode if you have access to a second Mac.
por
Sounds like you'll need to return it.
Pontuação 1
3 comentários:
Now that we know your exact machine, Dan's answer is correct. But in Target mode with another Mac, you can reformat the drive and install a new system.
por
My understanding is that Target Mode works only with FireWire (https://support.apple.com/en-us/HT1661). The MBA does not have FireWire.
por
No, you can also do it with Thunderbolt or even Ethernet connected macs
por
Adicionar a sua resposta
fredderf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 138
