My phone will not charge and I just replaced the battery?
I just replaced the battery on my phone, but the handset still will not charge. I'm not really sure what to do now. Do I have to buy a new handset?
Esta é uma boa pergunta?
You should not have to buy a new handset. If replacing the battery did not work, you can try to buy a new AC power cord. To order a new cord, you can either call the Uniden parts department at 800-554-3988 or order it here online. You can check our troubleshooting page for more information.
Esta resposta foi útil?
problem is of the three provided chargers, they all charge only one of the units, the other two do not charge at all, defect probucts for sure
I notice mind was a problem with the handset sitting to far back, I place some paper folded up behind and they charged.
Thanks I think that worked!
I have same issue w/3 new batteries & until yesterday, all 3 chargers worked. Now only 1 charger works, not base phone, but 1 of the extensions. Paper trick does not work, & I cleaned everything possible I could.
I had this issue after I moved my phone in my home office. I’d replace battery and it would stay charged for a few weeks but would not recharge. Turns out it didn’t like the power bar I had it plugged into. Plugged power source directly into wall and now it charged great.
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 71
Duração total: 14,456
1 comentário
por cgs
