Ir para o conteúdo principal
Lançado na primavera de 2014, o OnePlus One possui uma tela de 5,5" e roda o sistema operacional CyanogenMod 12S, baseado no Android. Modelo "ONE A0001".
broke the power button flex cable
hi,
i snapped the thin flex cable for the power button when trying to replace the screen. is there a part i can replace? or will soldering work?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I have this same issue. I have ordered a replacement cable. Does it require soldering or will it just clip into place?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Soldering skills of medium level will be required and a good iron with small tip (silver bearing (preferred) solder with good non acid flux as well). I would not advise anyone who does not have those skills to attempt repair unless you don't mind F@i& up the whole board. The ribbon can be bought online but it does require soldering.
Esta resposta foi útil?
Pontuação 3
oneplus one power flex cable
http://www.aliexpress.com/store/product/...
Pontuação 1
I did the same thing so I would be interested if you found a workaround
Pontuação 0
Adicionar a sua resposta
Damon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 2,979
