Ir para o conteúdo principal
No Boot on 12" PowerBook from factory disk
I thought there was a problem with hard drive after computer would not boot from hard drive or OSX install cd. replaced hard drive and am still having this problem, "The Computer will give the happy boot chime then it will start to boot on the hard drive but the monitor has grey lines in it. The computer will keep acting like it is booting but never completely boot. It just has the circle go around and around on the monitor with the lines in it."
booted in verbose mode and the last lines read:
Wed Jan 8 19:14:49 PST 2003; root: xnu/xnu-344.16.8.obj~5/RELEASE_ PPC
panic: We are hanging here...
any ideas? thank you
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi, Try removing and reseating your memory. If you have more than one memory chip install them one at a time. Good luck Ralph
Esta resposta foi útil?
Pontuação 1
1 comentário:
I am about to replace a hard drive in my power book aluminum 12¨but I ´ve lost the original os disc to reinstall it . Can I downloaded from the web?
Pontuação 0
1 comentário:
No--you have to contact Apple to purchase software.
por
Adicionar a sua resposta
John Paul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 1,856
